REVIEW
M1A2SEP Abrams with TUSKII
firstcircle
KitMaker: 2,190 posts
Armorama: 1,953 posts
Posted: Wednesday, October 07, 2015 - 01:00 AM UTC
Peter Ganchev reviews the latest version of the M1 Abrams fitted with urban combat kit, from Tiger Models.
Link to Item
Hisham
Al Qahirah, Egypt / لعربية
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Wednesday, October 07, 2015 - 01:44 AM UTC
Thanks for a great, comprehensive review, Peter.
The only thing I'm not crazy about are the one piece wheels and track.. but other than that it looks like a really nice kit.
I'm expecting a lot of nice things from Tiger-Models
Hisham
Vodnik
Warszawa, Poland
KitMaker: 4,305 posts
Armorama: 3,902 posts
Posted: Wednesday, October 07, 2015 - 07:36 PM UTC
It's a pity that main reference for this kit was the Tamiya 1/35 one, not original research... Several features present both in this kit and in Tamiya kit, but not existant in the real M1 make it clear.
pgp000
Grad Sofiya, Bulgaria
KitMaker: 58 posts
Armorama: 53 posts
Posted: Wednesday, October 07, 2015 - 11:57 PM UTC
@Hisham - thank you and agree. Hopefully by year's end we'll have a correction set. @Vodnik - for the benefit of all of us - why not share the knowledge?
metooshelah
#011
Jerusalem, Israel
KitMaker: 1,506 posts
Armorama: 1,304 posts
Posted: Thursday, October 08, 2015 - 12:43 AM UTC
thanks for a great review. i saw the kit but wasn't sure if i should buy it or not
Vodnik
Warszawa, Poland
Posted: Thursday, October 08, 2015 - 12:10 PM UTC
Take a look at the bottom hull tub - with the flat area in the center. In the real tank there is no such flat area there. The reason it exists in the Tamiya 1/35 kit is that originally it was designed to be motorized and this extra internal space there was needed for motorization parts (batteries?). Of course there is no reason for it in this small scale kit, but designers just copied the Tamiya kit feature without understanding its purpose. You can compare Tamiya kit part with other 1/35 kits:
Tiger kit:
Only Tamiya (and not shown here 1/35 Academy kit which also was mostly a modified copy of the Tamiya kit) has this flat bottom as you can see.
Another example are sizes of the rectangular suspension mounting plates on the hull sides. In the real tank the first, second and seventh (last) larger plates are IDENTICAL. But in Tamiya kit (and actually all other 1/35 kits except for newer Dragon M1A1AIM and M1A2SEP kits) the sizes of those plates are different - particularly the second one is too small. Also above the suspension mounting plates is a thicker armor plate along most of the hull length. It is represented in most 1/35 kits - although usually extends too far to the rear, but is missing completely from the Tamiya kit. And also missing from this Tiger kit. If designers of this tank used the real tank research, they should include that detail. But instead they based their design on Tamiya kit part.
Tiger:
Tamiya and others:
This is not the best angle, but you should be able to see the correct lower hull configuration as in the Dragon M1A1AIM kit (photo "borrowed" for discussion purposes from the AMPS website):
And a disclaimer at the end: I'm only posting this information because I was asked for it. I don't say that the Tiger Models kit is bad - it is probably one of the best, if not THE best modern Abrams in this scale (I don't know - it is not my scale). I just point out that it could be even better if some more effort was spent on research rather than just copying other manufacturer's design.
pgp000
KitMaker: 58 posts
Armorama: 53 posts
Posted: Friday, October 09, 2015 - 11:09 PM UTC
Thank you Pawel. Admittedly I don't tend to look at the bottom of my tanks a lot, but this will be helpful to modellers who'd like to get things right.
C_JACQUEMONT
Loire-Atlantique, France
KitMaker: 2,428 posts
Armorama: 2,320 posts
Posted: Friday, October 09, 2015 - 11:24 PM UTC
Exactly unless it's turned over or on a steep climb descent it will be hard to see anything.
I have the same benevolence for wrong interior detail that won't be seen once the top hull / turret is on and suspension stuff hidden behind skirts...
The older I get the more I think it's all about priorities and compromise. If the model is 80 to 90% right and what is normally seen when teh vehicle is on its base, I'm happy.
Now say the outside proportions are entirely off, the gun is too long or too short or the wrong thickness that's another matter.
Christophe
Biggles2
KitMaker: 7,237 posts
Armorama: 5,829 posts
Posted: Saturday, March 10, 2018 - 05:18 AM UTC
Comparing this Abrams to Flyhawk's shows the Flyhawk kit is much better, but so far they have not released a TUSK version. Wondering if the TUSK specific parts from Tiger would be compatible with Flyhawk's M1A2?? Any comments?
