Яusso-Soviэt Forum: WWII Soviet Armor
For discussions related to WW2 era Soviet armor.
Help with interior T-26
jhquiroz69
Yucatan, Mexico
KitMaker: 3 posts
Armorama: 3 posts
Posted: Thursday, July 13, 2017 - 03:47 PM GMT+7
Apreciated your help, i'm building a T-26, and need references for the interior, in specific: the floor-position from the gunner-, engine bulkhead, drive shaft & machine gun
ayovtshev
Sofiya, Bulgaria
KitMaker: 273 posts
Armorama: 260 posts
Posted: Thursday, July 13, 2017 - 07:51 PM GMT+7
Hi Jesus,
I assume you are building Soviet T-26(Vickers 6t. clone).Regarding interior: A)gunner seats in the right side of the turret, behind the machinegun; B) engine bulkhead is situated on the backside of what Russians called the "under-turret-box"- in other words running at true vertical from the starting point of the sloping engine compartment cover plate to the floor of the fighting compartment;C)the drive shaft runs through the middle of the lower part of the fighting compartment and unike the Vickers 6t. shaft it is horizontal; D) Machine gun-if it is Soviet T-26- is mounted in the turret, on the right side of the gun.
Hope this helps,
jhquiroz69
Yucatan, Mexico
KitMaker: 3 posts
Armorama: 3 posts
Posted: Sunday, July 16, 2017 - 05:40 AM GMT+7
Apreciated your answer Angel, do you have the pics...??? the description you made is great, but i'm more used to view, then guessing, rather than imagine and then do something...
deathdork
KitMaker: 187 posts
Armorama: 175 posts
Posted: Sunday, July 16, 2017 - 06:06 AM GMT+7
Check out the Osprey book series. I think there is a book on the T-26 and it consistent with the rest of the series should have a cut away layout that would be helpful to you.
ayovtshev
Sofiya, Bulgaria
KitMaker: 273 posts
Armorama: 260 posts
Posted: Sunday, July 16, 2017 - 07:01 PM GMT+7
Here you are Jesus:
Ramanathan
#477
Pest, Hungary
KitMaker: 97 posts
Armorama: 95 posts
Posted: Monday, July 17, 2017 - 01:58 AM GMT+7
Do any of you know whether Miniart's 35073 set (45mm ammo) is OK for a T-26 (and for the smaller turrets of the T-35)?
Many thanks!
Zsolt
ayovtshev
Sofiya, Bulgaria
KitMaker: 273 posts
Armorama: 260 posts
Posted: Monday, July 17, 2017 - 08:01 PM GMT+7
Zsolt,
I think MiniArt's 45 mm ammo should be OK for the tank version-the rounds for both tank(20-K) and antitank(19-K/53-K) guns have the same type designations(Б-240/О-240/Ш-240).
:-H
Ramanathan
#477
Pest, Hungary
KitMaker: 97 posts
Armorama: 95 posts
Posted: Monday, July 17, 2017 - 09:26 PM GMT+7
Zsolt,
:-H
many thanks!!
jhquiroz69
Yucatan, Mexico
KitMaker: 3 posts
Armorama: 3 posts
Posted: Thursday, July 20, 2017 - 11:44 AM GMT+7
Angel, thanks for your effort, but now i have another doubt, the floor on the gunner is raised at the level of the shaft...??? and with the assistant isn't...???
ayovtshev
Sofiya, Bulgaria
KitMaker: 273 posts
Armorama: 260 posts
Posted: Friday, July 21, 2017 - 08:50 PM GMT+7
Sort of,Jesus...
Rounds for the main gun were stored in metal cases on the floor bellow commander's seat, leaving a "tunnel" for the drive shaft. While standing, the commander stepped on these cases covers, but the machine gunner stepped on the floor.
Height of floor-I assume-was not so important in operation-both turret seats were mounted on the turret sides, they rotated with the turret, so the turret crew had the weapons always in front and in sight.
Hope this helps,
