PHOTOS
Upgunned Ferdinand
ColinEdm
KitMaker: 1,321 posts
Armorama: 1,203 posts
Posted: Wednesday, November 21, 2018 - 05:28 PM UTC
Arkadiy Sidorenko shares some pictures of his up-gunned Ferdinand based on Zvezda''s kit in 1/35.
Link to Item
tankmodeler
#417
KitMaker: 3,123 posts
Armorama: 2,539 posts
Posted: Thursday, November 22, 2018 - 07:35 AM UTC
Very cool idea.
May I suggest that if the mantlet and barrel are unpainted primer then the back of the mantlet would also be unpainted. You might want to touch it up if it's not too hard to reach, as I think it would help the whole idea be more cohesive.
Also, and this is just the engineer in me noticing things, if the Jagdtiger mantlet was being used, the factory may have torched off some of the lower lip to allow the gun to depress more. As it is, it is pretty much right at the lower depression limit with the barrel horizontal and most tanks like to sit as much hull down as possible to reduce their chances of being hit. Just a thought and it really doesn't detract from the cool idea you have going on.
Paul
Biggles2
KitMaker: 7,408 posts
Armorama: 5,967 posts
Posted: Thursday, November 22, 2018 - 10:24 AM UTC
You might want to upgrade your engine, transmission, and suspension while you're at it. Ferdinand/Elephant engines had a bad habit of overheating and catching fire due to the weight of the vehicle. You've just added several more tons with the bigger gun and mantlet, plus the heavier ammo!
HooFlungDung
KitMaker: 23 posts
Armorama: 15 posts
Posted: Tuesday, December 25, 2018 - 02:25 PM UTC
The fun thing about these What If builds. It frees the imagine to explore more creative Camo ideas. That the best part. Nice work.
